проекция многоугольника по ГОСТ 51794
Тема в разделе "Другие программы", создана пользователем ilovegeodesy, .
    Сильно:
    Код:
    {6212326.274570419,7543535.62790688},
    {6181860.299589701,7554524.910116848},
    {6170822.904022064,7548417.116165986},
    {6166457.151118587,7521673.970982113},
    {6166409.651748076,7492634.767155303},
    {6182196.549988738,6483555.32433239},
    {6218178.811830429,6445931.059716251},
    {6234628.029316824,6464366.708307678},
    {6250118.487136461,6473746.1853555245},
    Код:
    function POWER(x, y) {return Math.pow(x, y);}
    function RADIANS(x) {return x*Math.PI/180;}
    function sin(x) {return Math.sin(x);}
    function cos(x) {return Math.cos(x);}
    function FLOOR(x) {return Math.floor(x);}
    function getProjections(geoCoords) {
    	var projections = [],
    		maxL = 0,
    		minL = 180,
    		B, L, Lc, i;
    	for (i in geoCoords) {
    		L = geoCoords[1];
    		maxL = L > maxL ? L : maxL;
    		minL = L < minL ? L : minL;
    	Lc = minL + (maxL-minL)/2;
    		B = geoCoords[0];
    		L = geoCoords[1];
    		projections.push(getProjection(B, L, Lc));
    	return projections;
    function getProjection(latitude, longitude, Lc) {
    	var result = [],
    		n = FLOOR((6+longitude)/6),
    		l = RADIANS(longitude - Lc),
    		l2 = POWER(l, 2),
    		radLat = RADIANS(latitude),
    		sin2 = POWER(sin(radLat), 2),
    		sin4 = sin2*sin2,
    		sin6 = sin2*sin4;
    	result.push((6367558.4968*radLat - sin(2*radLat)*(16002.89 + 66.9607*sin2 + 0.3515*sin4 -
    				l2*(1594561.25 + 5336.535*sin2 + 26.790*sin4 + 0.149*sin6 + l2*(672483.4 -
    				811219.9*sin2 + 5420.0*sin4 - 10.6*sin6 + l2*(278194.0 - 830174.0*sin2 +
    				572434.0*sin4 - 16010.0*sin6 + l2*(109500.0 - 574700.0*sin2 + 863700.0*sin4 -
    				398600.0*sin6)))))) );
    	result.push(((5.0 + 10.0*n)*100000.0 + l*cos(radLat)*(6378245.0 + 21346.1415 * sin2 + 107.159*sin4 +
    		 0.5977*sin6 + l2*(1070204.16 - 2136826.66*sin2 + 17.98*sin4 - 11.99*sin6 +
    		 l2*(270806.0 - 1523417.0*sin2 + 1327645.0*sin4 - 21701.0*sin6 + l2*(79690.0 -
    		 866190.0*sin2 + 1730360.0*sin4 - 945460.0*sin6))))) );
    	return result;
    function getArea(coords) {
    	var result = 0;
    	for (var i = 0; i < coords.length-1; i++)
    		result += coords[0]*coords[i+1][1]-coords[1]*coords[i+1][0];
    	return Math.abs(result)/2000000;
  2. trir
    trir Форумчанин
  3. #23
    Спасибо, но это слишком тяжеловесное решение.
  4. stout
    А это-то зачем?
    Считал для Lc = 36.18724822995°
    ilovegeodesy нравится это.
  5. #25
    А, это и есть номер зоны. Убрал и получилось 5215.4. Погрешность больше 200 км2.
  6. trir
    trir Форумчанин
    номер зоны то зачем??
    Если считаем площадь, то все точки надо определять в одной зоне! (есть специальные 3-х градусные!)
  7. #27
  8. trir
    trir Форумчанин
    Что за сервер?
    ST_Area
  9. #29
    Здорово! Жаль, что в используемой мной СУБД (Sybase ASA 11.01) нет встроенных функций для работы с геообъектами.
  10. trir
    trir Форумчанин
    trir нравится это.
  12. trir
    trir Форумчанин
  13. #33
    Вопрос решен, считаю по ГОСТу с l = L - (Lmin + (Lmax-Lmin)/2).
    Спасибо всем за помощь!
  14. stout
    Вообще-то это только один из возможных способов выбора долготы осевого меридиана. Основная идея заключается в том, чтобы большая часть фигуры была как можно ближе к осевому меридиану.
    Если фигура симметричная относительно какого-либо меридиана, то можно и так считать.
    Далее можно слегка уточнить площадь, введя масштаб на осевом меридиане меньший единицы, так как это делается в проекции Transverse Mercator.
  15. #35
    точность хромает, но оставлю пока так. Ваш код с комплексными числами и гиперболическими тригонометрическими функциями я не стал пытаться реализовывать в SQL. Если потребуется более высокая точность, буду дальше двигаться. Спасибо за помощь!
