Подскажите где можно посмотреть список поддерживаемого оборудования? В максимагео звонил, обещали выслать и тишина.
X-PAD Survey Trial on Google Play 18 May 2017 X-PAD Survey Trial is now available on Google Play. The GeoMax X-PAD Survey Trial is a special version of X-PAD Survey that allows users to interact with X-PAD portfolio and increase the visibility of the GeoMax brand. Key Features: Downloadable free of charge from Google play Time-limit application (30 Days) Includes the main modules: TPS, GNSS, GIS, Road and Volume Allows use of the internal GPS receiver of the device used for the installation, or to enter TPS measures manually (angles and distance) No limitation in terms of points, import or export of data The GeoMax X-PAD Survey Trial is downloadable as a standard app from Google Play. You just need to open Google play on your Android device, searching for "GeoMax X-PAD Survey Trial" or using the QR code and then install. The GeoMax X-PAD Survey Trial will be available to download from Google Play from today onward. --- Сообщения объединены, 11 янв 2018, Оригинальное время сообщения: 11 янв 2018 --- teas, посмотрите список в триальной версии, так будет нагляднее.
