South G7 (inno7) x-fill
Тема в разделе "South", создана пользователем atsimeri, 3 июл 2022.
  1. atsimeri
    4 апр 2022
    i haven't been able to work with x-fill in my Galaxy G7 (inno7). although it is a bought option.
    In survx i choose enable x-fill in Device internet mode (rover), but when i close the data connection, the x-fill does not kick in. Also in the satellites tab, the Lband tab is empty.
    Has anyone managed to enable and work with x-fill? any advice?
    Sorry for the use of English, i don't speak Russian!
  2. avianvv
    Куратор
    28 янв 2021
    Hello.
    I think you don't have good solution at field.
    Or maybe you did not enable xfill at web-interface.
    My screenshots shows:
    1) xfill enabled at web-interface.
    2) xfill enabled at SurvX.
    3) fixed solution
    4) xfill work 28 second
    5) xfill work 87 second
    6) xfill disabled at 90 second
    I don't have easy situation at field.
  3. antonis26
    22 май 2021
    The best way to try if it is working is to go at an open field. 1) obtain a stable fix solution with low pdop, low age and a lot of satellites 2) after 1-3 minutes close only the internet 3) under fix solution the age should be growing, if age>30s and still fix then xfill is working if age> 30 and float or dgnss then x fill not working (xfill should be able to hold fix about age=>240)
    alek4mac и avianvv нравится это.
  4. alek4mac
    17 дек 2014
    Македония
  5. antonis26
    22 май 2021
    alek4mac, I just replied you with a personal message
    alek4mac нравится это.
