Connecting South Trimble board Gnss Receivers with Winflash
Тема в разделе "South", создана пользователем atsimeri, 8 фев 2023.
  1. atsimeri
    4 апр 2022
  2. antonis26
    22 май 2021
    It is not possible as I know.....
    Request from your dealer the new firmware, then you can flash it at your receiver through the web interface 10.1.1.1
    avianvv нравится это.
  3. atsimeri
    4 апр 2022
    i already have flashed the fw through the web interface but i need to check the gnss board options and fw warranty date
  4. css101
    8 окт 2021
    You can access winflash with south receiver but you need special service program that we won't be able to provide. I can estimate Trimble warrany date by serial number of your receiver. You can check if maxpro option is enabled by checking version of trimble firmware. If your version is 6XX that means that maxpro option is enabled.
    Also south receivers have two versions of firmware: south firmware and oem (trimble) firmware. Which one did you update?
  5. atsimeri
    4 апр 2022
    OEM. v 616. you may ask where did i find this firmware :p
    I constructed the fw .img file from the original trimble .timg file and uploaded to the receiver.
    antonis26 нравится это.
  6. antonis26
    22 май 2021
    How, great job!!!! From November we are still waiting from the south to release the 6.16.......
    Geomap2005 нравится это.
  7. atsimeri
    4 апр 2022
    South didn't even release 6.14
  8. atsimeri
    4 апр 2022
    Well, I finally did it.
    It is possible to connect the board to the receiver's serial port if you pass the appropriate command.
    Then winflash can connect directly to the trimble board.
    Geomap2005 и antonis26 нравится это.
  9. Geomap2005
    29 май 2023
    Hello, I have 2 South G6 with BD990. I cant upgrade the firmware OEM, dealer send to me update codes and 6.06 IMG file. I need help from all you. Thanks!!!
  10. atsimeri
    4 апр 2022
    Insert the update code first. Then reboot and upload the firmware img file
